Hello Guest it is November 13, 2026, 07:21:55 PM
Author Topic: Question about tool offsets  (Read 7520 times)
« on: November 18, 2014, 05:52:27 AM »
I have two tools, number 1 and number two.  Number two tool is .100 longer than tool 1.  When I set up Mach 3, I set tool 1 as tool 0 and zero it.  Then I set tool 2 offset.  The saved offset page shows that tool 2 is indeed .100 longer.  In Mach 3, when I switch from tool 1 to tool 2, I see the tool length offset in the window, so I know that Mach is registering.
Here is the puzzle.  When I press go to zero , tool 2 falls short by .040.  This phenomenon occurs only I first set up and calibrate the offsets.  Once I manually zero tool 2, it stay at the "new zero".
If this were a machine issue, I'd have issues with the material not cutting evenly. But, as I said, this happens only during calibration when I first set up the tools. Once I've corrected the offset manually, the tool keeps cuts to the correct depth.
I've measured the tool length and they are correct.
Am I missing something?
tony
tony
Re: Question about tool offsets
« Reply #1 on: November 18, 2014, 04:45:01 PM »
Not sure why you are setting tool1 as tool 0.
Try calling tool1 and G43H1 and then zero then call tool 2 with G43H2 and see.
