Hello Guest it is November 13, 2026, 09:41:09 AM
Author Topic: Cutting circle in SURFCAM too big! Help please.  (Read 9854 times)
Offline paulc
  •  15 15
« on: November 17, 2014, 04:25:21 AM »
Hi All,
Im just playing with my buddies Surfcam 2000, Im fumbling with it really.  Anyway I selected the inside of a 42mm dia circle.  Profiling.  Tool diam in SC is 8mm and TIP selected.  When I place a pencil in the machine it scribes a 68mm dia circle.  Why is this so big. Id expect the pencil to draw a 34mm circle.  ie 42-8mm tool dia =34.
See the G code surfcam created.  Perhaps Mach3 doesn't like the post type?
O0
G17 G40 G80 G90
T21 M6
S1194 M3
G0 G90 G54 X-17. Y0
G43 Z25. H21 M8
G0 Z2.
G1 Z0 F71.6
G3 I17. J0 F143.2
G0 Z25.
G0 M9
G28
M30
  •  9,377 9,377
Re: Cutting circle in SURFCAM too big! Help please.
« Reply #1 on: November 17, 2014, 06:10:53 AM »
Hi Paul,
Looking at your Gcode, the circle comes out at 34mm diameter here.
Perhaps you have your motor steps per unit set incorrectly ??
Offline paulc
  •  15 15
« Reply #2 on: November 17, 2014, 05:42:53 PM »
I sure the the steps are set ok.  Becuase when I measure straight movements in X and Y they are perfect.  Ie if I ask X to say move 50mm it moves 50mm same for Y, this is confirmed.  Also the circle is perfectly round just not the right diameter (68mm).  I could only think it was the post processor churning out the wrong code someplace.
Offline paulc
  •  15 15
« Reply #3 on: November 17, 2014, 07:12:19 PM »
Problem solved by Jeff Birt, he advised I needed to change the "IJ" settings in mach3 general config to incremental not absolute as it was set as.
All good now :)
