Hello Guest it is October 20, 2026, 07:59:03 PM
Author Topic: Tracking lost steps by comparing to previous home switch location?  (Read 9563 times)
jalbro
I'm wondering if Mach 3 can compare the current homing location to previous homing locations in order to see how many steps were lost since the last homing?
The idea:
The mill homes using the home switches (trip, and then untrip slowly) and finds out where it is in space.
Then you run a part.
If you then home again, Mach 3 should know where home SHOULD be. Is there a display view or program that will show you the difference of where home should be, and where Mach 3 finds it? It would be an easy way to find out if you are losing steps.
I've checked the manual, and googled around a bit, but didn't find anything.
-Jeff
jalbro
Re: Tracking lost steps by comparing to previous home switch location?
« Reply #1 on: April 03, 2007, 05:48:28 AM »
I found out that the button I'm looking for is "verify" on the MDI screen....
-Jeff
