Hello Guest it is October 12, 2026, 04:21:43 PM
Author Topic: Mach3 XML file compatability  (Read 9188 times)
« on: April 02, 2007, 05:58:36 AM »
  If I upgrade from Mach3 R1.84 to R2 can I use my original (R1.84) xml files?
BobL.
Re: Mach3 XML file compatability
« Reply #1 on: April 02, 2007, 07:02:40 AM »
Yes but you need to save a backup of your XML and copy it back in after you install the latest version. Also if you have axis slaving please be sure to check you settings after you install.
Brian
www.newfangledsolutions.com
www.machsupport.com
