Hello Guest it is November 09, 2026, 03:37:28 PM
Author Topic: Up is Down!! Z axis is moving in the Wrong direction.  (Read 8564 times)
« on: November 11, 2014, 08:11:45 PM »
hi,
My Z axis is moving in the Wrong direction! (by which I mean up=down & down=up) Any idea how to fix it? Is it switching wires? Wonder which ones. And do you think I can hurt anything by switching the wrong ones?
Here's the machine's Motion Control Card:
Re: Up is Down!! Z axis is moving in the Wrong direction.
« Reply #1 on: November 11, 2014, 09:24:56 PM »
Go into Config - Ports & Pins - Motor outputs and toggle, Dir Low Active setting.
You may then need to set up your homing directions to suit, under Homing Limits etc.
Pretty sure that will get you there. It's been awhile since I have done all that kind of tweeking.
« Reply #2 on: November 11, 2014, 09:28:15 PM »
You can also just check the Reverse box in Config > Homing/Limits
