Hello Guest it is October 05, 2026, 03:42:49 PM
Author Topic: using inputs to run code  (Read 7386 times)
« on: November 10, 2014, 11:55:06 PM »
hi guys,
I'm kind of new to this so sorry if I'm not clear,
I have a machine set up with two working stations, and i would like to have two different gcodes run on the the different stations,
I need a to write a code that will choose what part of the g-code to run based on operator input,
in simple words, I have "input1" and "input2" and depending on witch one is active I want the machine to run a specific part of my gcode.
I would prefer not to use vb since I have run into quite a bit of problems while using vb.
thank you all for your help.
Re: using inputs to run code
« Reply #1 on: November 11, 2014, 04:54:58 PM »
ACtually VB Is fine for things like this in mach3. Just don't mix the VB and gcode in the same macro. Use the VB to load a file based on the input then the Machine will run the Gcode native.
