Hello Guest it is November 13, 2026, 12:17:12 PM
Author Topic: smoothstepper port 2 not working  (Read 10281 times)
« on: November 08, 2014, 11:29:41 PM »
I am setting up an old digital meta machine with an Anaheim automation motor control. I have a windows xp pc and an ethernet smoothstepper along with a wireless hand control. I have the smoothstepper and the wireless control moving the x and y axis steppers (drive belts removed) but I cannot get the z to move. the z brake is on as I can feel the stepper fight me trying to turn it by hand. To double check the z wiring and the Anaheim control I swapped the 25 pin cables, the motor pinouts are the same for each cable x-z and y-w so with this configuration I should have been able to move the z with the x (yes) and the x with the z (no) and the y with the w (no) z and w are on the second port so with all of this in mind I think either the software is disabling port 2 function or port 2 is somehow disabled in the smooth stepper set up.
I have ohmed out the Anaheim controller (picture attached) and I have these wired straight thru to the smooth stepper. I believe I will need to make cable as the x++ limit is on pin 1 and from what I can see only 10-11-12-13-15 are valid inputs
« Last Edit: November 08, 2014, 11:31:39 PM by BigKrateKustoms »
Re: smoothstepper port 2 not working
« Reply #1 on: November 09, 2014, 07:50:33 AM »
I see I did not mention I have it running on Mach3 free version.
« Reply #2 on: November 09, 2014, 11:22:00 AM »
looks like it was the smoothstepper. on the plugin configuration page there is an option for port 2 and port 3 2-9 to be input, these are both default to input. Once I changed port 2 pins 2-9 to be output my Z axis is now working
« Last Edit: November 09, 2014, 11:24:39 AM by BigKrateKustoms »
