Hello Guest it is November 13, 2026, 09:59:54 AM
Author Topic: Turn off outputs on exit  (Read 7968 times)
« on: November 08, 2014, 05:07:47 PM »
I was just wondering if there is any way that Mach3 deactivates/turns off outputs when I exit Mach3, because now they stay turned on and it's a bit annoying. If i hit reset, all outputs are deactivated/turned off, I want this to happen when I exit Mach3. I just couldn't find a solution for this. Can anyone help me?
Thank you very much!
Offline rdean
  •  94 94
Re: Turn off outputs on exit
« Reply #1 on: November 08, 2014, 06:28:23 PM »
look up Charge Pump it will do what you want.
Ray
