Hello Guest it is November 13, 2026, 09:37:49 AM
Author Topic: Altering a Macro Help please.  (Read 10637 times)
« on: November 07, 2014, 04:04:02 AM »
Hey All,
Need some help from the code junkies please.. I have an existing macro that does my homing and a tool pro be for me.  it runs like so:
Z, Y, X then Probe.  https://www.youtube.com/watch?v=gQVm4YjLM3E
I have since upgrade to a 5th axis, and I need to home A and B as well..
BUT
B = no issue as it cannot crash anything//
A = Issues..
then script will need to run as follows now:
action sequence:
1. Home Z: then Move Z to a safe distance. (say 10mm down from home switch)
2. Home X: then Move it to Fixture 1(g54) X0  (XYZ share one input signal, I have to move off the switch for next axis homing run)
3. Home Z: then move it to Fixture 1(g54) Y0  (XYZ share one input signal, I have to move off the switch for next axis homing run)
4: Home B:
5: Home A: then move A to -A45
6: Probe Tool: (note Z MUST stay at same height until its directly over tool probe before going Down Z.
7: Return to the safe Z (10mm below Z probe) over X0andY0
So! Most of the code already exists, and the tool probe position is programmed via my interface so all I need added are the A and B bits..
Any help appreciated folks!
(here is the current standing of my build, jsut about ready to start making noise!! https://www.youtube.com/watch?v=gQVm4YjLM3E)
and attached is the current Macro. (adding it as file because code is being converted into smiley characters by forum)
HomSigY = IsActive(5)
HomSigZ = IsActive(8)
Xreferd = GetLED(7)
Yreferd = GetLED(8)
Zreferd = GetLED(9)
If HomSigX Or HomSigY Or HomSigZ = True Then
        MsgBox("Home switch active...please deactivate before tool change.")
        Exit Sub
End If
If Xreferd Or Yreferd Or Zreferd = True Then
        MsgBox("Axis not referenced...please home all first.")
        Exit Sub
End If
LastFeed=GetOEMDRO(818)
SetUserLED(1001,False)
SoftState = GetOEMLED(815)
If SoftState = True Then
DoOEMButton (119)
SetUserLED(1001,1)
End If
SetUserLED(1002,0)
WorkUnits = GetOEMLED(801)
If WorkUnits = True Then
code "G21"
SetUserLED(1002,1)
End If
DoOEMButton(104)
While IsMoving()
Sleep 100
Wend
xTSensPos = GetUserDRO(1200)
yTSensPos = GetUserDRO(1201)
code "G00"
code "G53X" & xTSensPos & "Y" & yTSensPos
While IsMoving()
Sleep 100
Wend
SensGapPos = GetUserDRO(1203)
code "G00"
code "G53Z" & SensGapPos
While IsMoving()
Sleep 100
Wend
zTSensPos = GetUserDRO(1202)
SensSpeed = GetUserDRO(1204)
code "G31Z" & zTSensPos & "F" & SensSpeed
While IsMoving()
Sleep 100
Wend
CurrFixture=GetOEMDRO(46)
Select Case CurrFixture
Case 2
     ProgXZero = GetUserDRO(1209)
     ProgYZero = GetUserDRO(1210)
     ZtoProbe = GetUserDRO(1212)
Case 3
     ProgXZero = GetUserDRO(1213)
     ProgYZero = GetUserDRO(1214)
     ZtoProbe = GetUserDRO(1216)
Case Else
     ProgXZero = GetUserDRO(1205)
     ProgYZero = GetUserDRO(1206)
     ZtoProbe = GetUserDRO(1208)
End Select
SetDRO(2,ZtoProbe)
code "G00"
DoOEMButton(104)
While IsMoving()
Sleep 100
Wend
code "G00"
code "G53Y" & ProgYZero & "G53X" & ProgXZero
While IsMoving()
Sleep 100
Wend
If GetUserLED(1001)= 1 Then
DoOEMButton (119)
SetUserLED(1001,0)
End If
If GetUserLED(1002)= 1 Then
code "G20"
SetUserLED(1002,0)
End If
« Last Edit: November 07, 2014, 04:06:11 AM by Chris.Botha »
Offline Vogavt
  •  260 260
Re: Altering a Macro Help please.
« Reply #1 on: November 08, 2014, 01:19:00 PM »
Use "code" instead of "quote". It's the hashtag to the left of the insert quote button  <grin>
Code: [Select]
HomSigZ = IsActive(Cool
Xreferd = GetLED(7)
Yreferd = GetLED(Cool
Zreferd = GetLED(9)
        Exit Sub
End If...................
« Reply #2 on: November 08, 2014, 03:59:23 PM »
Thanks I got help.  Issue resolved
