Hello Guest it is November 13, 2026, 09:34:21 AM
Author Topic: How to get rid of offset  (Read 10442 times)
« on: November 06, 2014, 12:08:46 PM »
I have this line every single time in the G code.
N140G00G43Z20.320H1
If I leave it, it screws up the Z auto zero after I zero it.
I delete it every time and it's fine. How do I get it to stop inserting it??
Offline rcaffin
  •  1,073 1,073
Re: How to get rid of offset
« Reply #1 on: November 07, 2014, 02:27:31 AM »
Since I have NO IDEA what program you are using to generate that code, I have NO idea!
In fact, I seriously doubt it has anything to do with Mach whatsoever.
  •  9,377 9,377
« Reply #2 on: November 07, 2014, 07:07:52 AM »
N140G00G43Z20.320H1
I presume you are using a Vectric CAD/CAM - in which case locate the post-processor you are using and delete the codes you do not want to appear in that line.
