Hello Guest it is November 13, 2026, 05:19:26 PM
Author Topic: Pokeys57E with LCD enable problem  (Read 12233 times)
« on: November 05, 2014, 11:16:56 PM »
I have problems where pulsing is not smoother, graphic on tool path window and  x, y, z DRO value run away from actual value.
It took me few days to track down this problem. I did change several things such as PC, Windows version, Pokeys setting before I spot problem when I disable LCD feature then the problem is gone.
I have designed a BOB for Pokeys, named PoBOB, which allows users to attache LCD on the bottom of BOB in case they want to attach it in the back of panel. I conducted several tests, including LCD. However during one test, I didn't realize having removed LCD  from Pokeys could cause mentioned problem.
Here is my prototype and introduction in Thai
<a href="http://www.youtube.com/v/aDQQaqN6FiA?hl=en_US&amp;amp;version=3&amp;amp;rel=0" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/aDQQaqN6FiA?hl=en_US&amp;amp;version=3&amp;amp;rel=0</a>
I hope next version of Plugin will detect whether LCD attach or not. :D
The CNCRoom.com, the place where Industrial Hobbyists can talk and trade!
www.cncroom.com/forum
