Hello Guest it is October 20, 2026, 11:54:03 PM
Author Topic: Lazycam not generating ALL the g-code?  (Read 9177 times)
« on: October 30, 2014, 05:37:23 PM »
I am trying to cut a gear. This gear has 3 spokes. Therefor, the cam shows basically 5 chains. 3 chains for the voids between the spokes, 1 chain for the hole, and one for the teeth. This seems to look basically correct inside lazycam. However, when it generates the gcode, it only generated the code for one of the voids, and then puts some G42's behind it (about a dozen) and nothing else. Why is it stopping?
Re: Lazycam not generating ALL the g-code?
« Reply #1 on: October 30, 2014, 06:34:04 PM »
Do you have a Mach3 license?
« Reply #2 on: October 30, 2014, 07:02:18 PM »
Yes. And I have had it generate MANY more lines than this before.
« Reply #3 on: October 30, 2014, 07:08:47 PM »
My bad... it's the license. I had loaded on my laptop for the purpose of not having to stand in front of the machine the whole time I'm tweaking the files and I forgot it loaded in demo mode.
