Hello Guest it is November 13, 2026, 05:31:22 PM
Author Topic: G31 causes an endless loop  (Read 24700 times)
Offline PtD
  •  9 9
Re: G31 causes an endless loop
« Reply #10 on: October 31, 2014, 03:44:18 PM »
I confirm the same behavior both in licensed and demo mode.
I would suspect some quirks with the controller, but I can't see how the controller can cause a step back in the execution order in Mach3...
« Reply #11 on: October 31, 2014, 04:48:17 PM »
If you're not using the parallel port, many external motion controllers have G31 bugs in their plugins.
Whenever you're using a motion controller, make sure you specify that up front when asking questions, as it can save days of frustration.
Offline PtD
  •  9 9
« Reply #12 on: November 01, 2014, 11:42:17 AM »
Right. The controller is YooCNC USB motion card (the one from X6-1500GT). What I see is that G31 is correctly executed - it touches probe and then program moves to another step. What could be the reason that G31 command (executed with whatever controller) is making Mach3 go back a line?
« Reply #13 on: November 01, 2014, 12:46:28 PM »
As I said, it's probably a bug in the plugin for your motion controller.
Report the issue to the developer of the device, and see if they can fix it.
Offline PtD
  •  9 9
« Reply #14 on: November 02, 2014, 05:25:27 PM »
Follow up: This VB code works fine:
Code: [Select]
For y = 0 To 10
For x = 0 To 10
Code "G0 Z1"
Code "G0 X" & x & "Y" & y
While IsMoving()
Sleep(10)
Wend
Code "G31 Z-10"
While IsMoving()
Sleep(10)
Wend
Sleep(10)
zProbe = GetDRO(2)
Message "x " & x & ", y " & y & ", z " & zProbe
Next
Next
It seems that the problem is related to timing issues. If I omit the sleep(10) before the GetDRO(2) call, I get spurious values for Z.
Based on this VB script, I developed a wizard that does the whole digitizing in VB. I will keep trying to resolve the issue in G-Code.
Thanks for your support.
