Hello Guest it is October 20, 2026, 02:55:06 PM
Author Topic: Mach3 1.5  (Read 8752 times)
Mach3 1.5
« on: October 23, 2014, 11:47:15 AM »
I recently updated to Mach3 1.5 from 1.1 ,after resetting up all ? the perameters I encoutered this problem with the y axes only, every time I run a file the y axes over runs Zero by about .5 in when I do a goto Zero. The DRO for y axes says its at zero. If I drive it off with the jog it returns to Zero as it should. Any thoughts?
  •  9,374 9,374
Re: Mach3 1.5
« Reply #1 on: October 24, 2014, 02:26:23 AM »
I am not sure which revision of Mach3 you are referring to - the latest version appears to be R3.043.066   ???
Re: Mach3 1.5
« Reply #2 on: October 24, 2014, 02:49:30 PM »
Yep, Mach 3 R3.043.066
sorry
