Hello Guest it is November 20, 2026, 10:33:31 PM
Author Topic: GetVar(2002)  (Read 26922 times)
Offline amnon
  •  40 40
GetVar(2002)
« on: October 21, 2014, 12:05:38 AM »
Hay,
Code "G31Z-10 F100" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Could some one explain me why is that when I put MsgBox ZProbePos I have always 0
Regards
Amnon
Offline TPS
  •  2,627 2,627
Re: GetVar(2002)
« Reply #1 on: October 21, 2014, 01:59:22 AM »
hope you are putting the value into MSGbox like this:
MsgBox cstr(ZProbePos)
should work. i do it in the same way.
regards Thomas
Offline amnon
  •  40 40
Re: GetVar(2002)
« Reply #2 on: October 21, 2014, 04:07:23 AM »
Thank's
What does "cstr" mean
Regards
Amnon
Offline TPS
  •  2,627 2,627
Re: GetVar(2002)
« Reply #3 on: October 21, 2014, 04:54:25 AM »
cstr converts numbers to string, because msgbox can only display string.
look here: http://www.machsupport.com/help-learning/product-manuals/
for vb script manuals
Re: GetVar(2002)
« Reply #4 on: October 21, 2014, 06:05:00 AM »
You usually don't need to convert to a string to put something in a messagebox.
Offline TPS
  •  2,627 2,627
Re: GetVar(2002)
« Reply #5 on: October 21, 2014, 08:49:36 AM »
you are right with the example above.
but only in this case:
Test = 1234.5
MsgBox Test
not in this case:
Test = 1234.5
MsgBox "Test = " + CStr(Test)
Thomas
Re: GetVar(2002)
« Reply #6 on: October 21, 2014, 08:57:39 AM »
Correct, if you want both string and numeric data, you need to convert all to sting data as you've shown.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: GetVar(2002)
« Reply #7 on: October 21, 2014, 09:39:58 AM »
depends on which concatenation operator you use (+ or &)
Test = 1234.5
MsgBox "Test = " & Test
is fine.
Re: GetVar(2002)
« Reply #8 on: October 21, 2014, 09:49:08 AM »
Also correct. :)
Offline amnon
  •  40 40
Re: GetVar(2002)
« Reply #9 on: October 22, 2014, 05:51:15 AM »
How macro knows that after :
Code "G31Z-10"
While IsMoving()
Wend
Z axis should be put into 2002(ZProbePos)
Respect
Amnon
