Hello Guest it is September 05, 2026, 09:14:00 PM
Author Topic: Homing using Ref Home  (Read 12111 times)
« on: October 19, 2014, 10:59:12 AM »
Hello,
My Machine works well now, except, when homing the slaved axis.
The Y axis has a homing switch, agh Axis doesn't, when i select Ref Home the machine homes and then moves away from the switches, all seems well.
The problem is:  the A axis is slightly out of sync with the Y axis, and each time i ref home the error it is out by the same amount again, its about .6mm out each time i hit ref home button.
The machine is pulley and belt driven so if i Ref home 7 or 8 time in succession, the machine jumps a tooth on the pulley.
Could the Y axis motor not be in sync with the A axis motor?
If not any ideas?
I am using a UC300 controller from cnc4you
Re: Homing using Ref Home
« Reply #1 on: October 19, 2014, 11:10:30 AM »
In General Config, do you have "Home Slave with Master" checked? It needs to be.
« Reply #2 on: October 19, 2014, 11:44:36 AM »
Yes, it is set
« Last Edit: October 19, 2014, 11:47:05 AM by piccyman »
« Reply #3 on: October 19, 2014, 11:50:07 AM »
Could be an issue with the plugin for your device.
« Reply #4 on: October 19, 2014, 11:56:37 AM »
I have just updated the driver and firmware just in case.
If I disable the slave axis, and unplug the motor it works fine
« Reply #5 on: October 19, 2014, 12:51:45 PM »
everything else works ok, the machine will always go back to working zero fine, and I never have any unexplained stops, so there is no problem with noise
