Hello Guest it is November 13, 2026, 05:18:21 PM
Author Topic: Pendant, Pokeys USB Board, Encoder values glitches in Mach3  (Read 13474 times)
Offline GerdS
  •  42 42
« on: October 17, 2014, 07:19:50 AM »
Hi Guys,
weeks ago i finished my Mach3 Pendant with a Pokeys USB board.
So far everything works like expected, but i have a problem that my encoders value jumps up and down.
I can't see any movements in the pokeys diagnostic page, but the Mach3 Encoder positions jumps up and down for some values.
This results in speed jumps when i use the Rotary encoders for moving axis, Spindle and feed override.
Thats a very uncomfortable feature i don't realy want.  :o :o
I use the Pokeys Rotary encoder for axis moving and two ALPS 15/30 pulse/detent (STEC11B03) encoders to adjust the feed and spindle speed.
In case of spindle and feed speed, I tried different solutions to connect to Mach3.
Macropump script, Brains and the pokeys plugin to connect to the DRO's directly.
Same results. ???
I also use a double shielded cable to connect the pokeys board.
But nothing helped.
Is there any other Trick to rid off this unwanted feature.
Do i need any additional resistors or capacitors to connect between the encoders to remove glitches. ?
Gerd
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pendant, Pokeys USB Board, Encoder values glitches in Mach3
« Reply #1 on: October 19, 2014, 11:28:20 PM »
Do the values jump up and down when the encoders are stationary or when these are moved?
Matevz
Offline GerdS
  •  42 42
« Reply #2 on: October 22, 2014, 04:26:42 AM »
Hello Matevz
The values for the Feed or Spindle Encoder jumps up and down also without any interactions. It's a bit more after i did some turns with the encoder.
(But only visisble in the Mach3 Encoder DRO's not in the Pokey diagnostic tab.)
With the MPG Encoder, i can not see any values up and down. Only when i us it to move any axis for positioning, then some times the speed raise up to the highest for just a second.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: October 22, 2014, 12:00:48 PM »
It appears that something is overwriting the same OEM DRO as PoKeys. Have you configured anything else?
Offline GerdS
  •  42 42
« Reply #4 on: October 24, 2014, 02:45:58 PM »
I think i have got the problem for the Feed and Speed Override.
When i turn the knob and watch the Encoder values on the IO status tab. I see that sometimes the Encoder increment 2 values and sometimes just 1 value and with a short delay it increments to 2
Could it be, that the ALPs Encoder grid is not in sync. And is there a way to handle it. Maybe by reducing the sensitivity.
I also wanted to mention that i use a smoothstepper board.
There are some settings for the sensitivity i don't handle it right now.
