Hello Guest it is October 21, 2026, 12:07:28 PM
Author Topic: Question... G54 default fixture offset ?  (Read 10129 times)
« on: March 29, 2007, 03:12:43 PM »
Hi Ya'll ;
I am running Mac3 ver 2  60 . When I startup mach and go to the offset page , all my fixture offsets are correct   except G54 (which is all Zero's) .
Is this because after homing the machine G54 is set to 0,0,0 by default ? If so , how can I work around this ?
Great group.... Paul W
Re: Question... G54 default fixture offset ?
« Reply #1 on: March 29, 2007, 03:31:30 PM »
Have a look in the Config menu then General config, at the lower right of the page you will see a setting "Copy G54 from G59.253 on Startup" make sure this is unchecked.
« Reply #2 on: March 29, 2007, 03:53:57 PM »
 :) Thanks Hood . This fixed the problem .  I also thought that I could Home the machine and zero
out the DRO's and then goto the offset page and select the fixture offset (in my case G54), but zeroing the
machine sets the G54 to zero . thanks again Paul W
