Hello
Guest
it is
October 20, 2026, 04:07:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach control pendant switches
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach control pendant switches (Read 9256 times)
mrosso
9
on:
March 28, 2007, 02:11:51 PM »
What type of switches do I need to do things like turn on coolant, switch axes for my mpg, and turn on/off other things in Mach? Can I use momentary switches or do I have to use continuous/toggle switches?
PS- my setup is G100 & Mach 3
Logged
Re: Mach control pendant switches
Reply #1 on:
March 28, 2007, 03:05:21 PM »
Depends how you are interfacing them with the computer, I dont know about the G100 so cant say on that but if you have a keyboard emulator then momentary switches is what you want, if you are using pins on a port then toggle I would think.
Logged
Print
Pages:
1
Go Up
« previous
next »
