Hello Guest it is October 20, 2026, 04:45:41 PM
Author Topic: Peck Drilling not working in Mach3 Turn  (Read 10199 times)
« on: September 22, 2014, 02:00:03 AM »
 I've been trying to figure out why Mach3 Turn will not execute the G83 peck drilling operation
for the last couple of days and have had no success. I use G83 operations on my mill and router
all the time but I've never done a drilling operation of any type on my lathe before. I've tried
changing different settings in my Mach Turn setup but nothing seems to work. I'm operating
under the assumption that G83 works in Turn the same as Mill and have read nothing contrary
to that so what could be wrong that it doesn't? If anyone has any insight into this problem
please let me know because I'm out of ideas.
Don
Re: Peck Drilling not working in Mach3 Turn
« Reply #1 on: September 22, 2014, 04:47:30 AM »
Don,
For peck drilling on the lathe try the lathe macro you will find in the link below. There is a read file which
which you should read. Works great and i have used it manny times.
http://www.machsupport.com/forum/index.php/topic,15205.msg101682.html#msg101682
Offline Rimmel
  •  284 284
« Reply #2 on: November 20, 2018, 04:23:36 AM »
Don,
Hi Rich the link is broken - do you have a woking link?
Ah sorted it - it seems the forum url's have changed
It is now http://forum.machsupport.com/forum/index.php/topic,15205.msg101682.html#msg101682
thanks
« Last Edit: November 20, 2018, 04:25:39 AM by Rimmel »
