Hello Guest it is November 11, 2026, 05:26:18 PM
Author Topic: Where is the main screen???  (Read 17702 times)
« on: September 21, 2014, 10:31:29 AM »
A few days ago I noticed that on startup, MachScreen  display only the Properties window.
The main screen is visible only  a piece of second and then disappears.
I tried on the other two computers and everywhere is the same.
I've tried re-installing MachScreen, but nothing  ...
What happened?
Is there any way to solve this problem?
Thanx!
Re: Where is the main screen???
« Reply #1 on: September 22, 2014, 04:05:05 PM »
Hello,
try to hold down the key A, then start MachScreen, keep the key pressed until MachScreen is showing up. All Settings are set to default.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: October 01, 2014, 02:23:25 PM »
It does not help. I still can not properly run the program.
Is there any other option?
Thanx!
« Reply #3 on: October 01, 2014, 02:54:22 PM »
Sorry, I gave you the wrong key combiation. You have to hold down the Shift key instead of A and start MachScreen. After saving the screenset it should be shown normal at next start.
Klaus
« Reply #4 on: October 02, 2014, 12:03:36 PM »
It works!!! :D :D :D
Thank you Klaus!
