Hello Guest it is November 13, 2026, 10:02:17 AM
Author Topic: Something wrong with my setting or ??? - NEWBIE - help wanted  (Read 8275 times)
« on: September 20, 2014, 03:49:37 AM »
Hi
I have a cnc router 3040 from ebay - I got the control box there is black, if you know it well.
I use xp proff.
2 of the axis are running but not all 3
I have been tested the machine like this:
Power on the controlbox - it take over on all 3 motors - not to be rotated by hand.
I think it is the motor output signals pin 4 and 5 - why...
It is allways the Y+ and Y- where wont drive on the tab board.
Please help with any suggestions.
/Per
Re: Something wrong with my setting or ??? - NEWBIE - help wanted
« Reply #1 on: September 20, 2014, 06:15:25 AM »
 ///////////////Configuration Check Facility///////////////////////
 Any obvious errors are checked by this facility, passing does not mean
 you have no errors, but as more error possibilities are found,
 more checks will be added to this facility.
 Currently, the most frequenct tech-support errors are checked for.
 ///////////////LIMIT & HOMING CHECK///////////////////////
No Errors Found!
 ////////////////////// End of Homing and Limits Check ///////////////////////////////////
 ///////////////OUTPUT Signals Check///////////////////////
 No port/pin errors found in output signals.
 ///////////////End of OUTPUT Signals Check///////////////////////
 //////////////// Digitising Probe /////////////////////////
 /////////End of Probe Check /////////////////////!.
 /////////Motor Settings - Enabled Motors only are Checked/////////////////////!.
 A motor Step pin is set to a port other than 1 or 2, this is probably an error..
 A motor Direction pin is set to a port other than 1 or 2, this is probably an error..
 /////////Motor Settings - End of Motor Checks/////////////////////!.
 Checkup complete , please check any errors listed.
 Thank you for checking your Settings.....
My config file
