Hello Guest it is November 22, 2026, 11:11:20 PM
Author Topic: Has anyone used a Cmore touchscreen with Mach3  (Read 8627 times)
« on: September 17, 2014, 01:44:29 PM »
I was wandering if anyone has used a Cmore touchscreen with mach3 cnc.  I am trying to make a remote terminal on my table cnc to be able to move axis's, tool zero, laser on/off, vacuum table zones and ect.  I really would like to use it if I can.  I think it would be pretty cool if I could.  I then could add a physical Estop.  The part number is EA7-S6M. This screen does have a Serial PLC Port: RS-232/422/485 15-Pin D-sub (female) and ethernet.  Here is the info on screen.  http://www.automationdirect.com/static/specs/ea7s6mr.pdf
Thank you in advance if any one has any knowledge on this......
Offline BLM
  •  37 37
Re: Has anyone used a Cmore touchscreen with Mach3
« Reply #1 on: September 19, 2014, 08:52:20 PM »
I can't answer your question on that particular screen, but if you are just looking for touch screen control here's what works for me. I built my own steel enclosure and fastened a Dell 2020 All-in-one with Capactiive touch, to the inside of the front panel. I used 3M automotive molding tape to fasten it. Works beautiful! Thanks, Brian
