Hello Guest it is November 13, 2026, 11:03:38 AM
Author Topic: 6 axis Robotic with Mach3  (Read 7307 times)
« on: September 17, 2014, 08:54:41 AM »
Hi all,
        I searched around the forum on 6 axis control with Mach3, not much about 6 axis robotic were found. I'm sure Mach3 can manage to control a 6 axis articulated robot with the right post processor.
Mach3 is based on Fanuc ISO, is this correct?, If so, then I can use a CAM software with a Fanuc robot post processor or some similar Mach3 5 axis post for the robot, or is it not as easy as it sound?
I know EMC2, I have tried it but not used to it.
If someone know more about this field or maybe explain a little bit why mach3 can not do that would be great.
thanks,
