Hello Guest it is November 13, 2026, 05:54:51 PM
Author Topic: problem with joystick  (Read 12634 times)
« on: September 12, 2014, 03:15:00 AM »
I have use this kind of joystick plugged in a Pokeys56U and every time i turn on Mach3 and the pendant, axis moves
I have to open the config and calibrate again the joystick.
When it is in the neutral position I see the volt value continuous variable .
The dead zone is set at 45, less then 40 I have problem
the joystick is this
Offline NeoTO
  •  504 504
    • PoLabs
Re: problem with joystick
« Reply #1 on: September 12, 2014, 01:23:55 PM »
That is what deadband is meant for. Even 45 is quite a low value.
« Reply #2 on: September 14, 2014, 05:35:21 PM »
I have tryied to put deadband at 80, 100 but always the same, axis move by themselves.
Very dangerous when you leave the machine stopped and you see it move alone.
Maybe joysticks in this application are not a good idea.
And when I use joysticks to move head slow, I always receive back an error from UC100 connection
« Last Edit: September 14, 2014, 05:38:01 PM by progress »
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: September 14, 2014, 11:07:35 PM »
Are you using UC100 or PoKeys to drive the steppers?
« Reply #4 on: September 15, 2014, 01:36:13 AM »
no, I use UC100 to connect my laptop (it have not a parallel port) to a control board with the parallel port.
It work very well, I never had a problem.
The parallel board control 4 external driver CW8060
I have also a Contour Shuttlexpress and it work fine, I can control axis and jog with it.
Now i have Pokey56U and I have assembled a Jog pendant
