Hello Guest it is November 22, 2026, 05:20:56 PM
Author Topic: Ethernet smooth stepper problems  (Read 8340 times)
« on: September 06, 2014, 08:02:52 PM »
Hi All
I have a 5 vDC power supplying the board. I assume I have the + and - DC voltage correct. At this time
I do Not see any LED so I`m not certain the board has power. I did the network adapter configuration
but since I`m getting no feed back I have no idea what is wrong.
Re: Ethernet smooth stepper problems
« Reply #1 on: September 08, 2014, 12:52:07 AM »
I suggest you contact Greg, if there are no LEDs then it sounds like either there is no power getting to the ESS or you may have blown it by wrong polarity, Greg will be able to advise..
