Hello Guest it is November 13, 2026, 05:54:25 PM
Author Topic: configure joystick in Mach3  (Read 13627 times)
« on: September 06, 2014, 04:55:33 PM »
Hello,
I have connected a 2 axis joystick in the pokeys, with 2 potentiometers (resistor)
In the page of plugin inside Mach3 I'm not able to find the rigt DRO to set to use the joystick to move the axis.
I need to move axis incremental, eg. i turn the joystick for 30% the X move at 30% of velocity
I hope to explain right
thanks in advance for help
Re: configure joystick in Mach3
« Reply #1 on: September 07, 2014, 12:33:12 AM »
see pict.
hope that helps.
Alex
« Reply #2 on: September 07, 2014, 03:42:53 PM »
great, now works, thanks.
Another question about: I have a switch on the joystick, can I use this to enable/disable the joystick function?  How i can do this? Someone know the OEM button to check?
thanks
« Reply #3 on: September 08, 2014, 02:54:21 PM »
it looks like it is not possible to enable/disable the Pokeys joystick function with an OEM button or a pokeys input.
At least I didn't get it.  ???
Alex
« Reply #4 on: September 08, 2014, 04:36:41 PM »
I've asked it for safety, because I can touch it moving my hand and make a disaster
