Hello Guest it is November 03, 2026, 10:51:05 PM
Author Topic: Hypertherm Plasma Interface cable  (Read 12938 times)
Offline BLM
  •  37 37
« on: September 05, 2014, 08:57:53 AM »
Hi, I am installing a HD3070 HiDef Plasma cutter on a Mach3 run, homebuilt plasma table. Can anybody help interpret the I/O of the Machine Interface cable?( see attached scan) I have a good idea of what some of the wires do but it seems that some probably won't be used by Mach3. What is meant by (Dry) behind some of the descriptions? Any ideas would be appreciated. Thanks, Brian
Re: Hypertherm Plasma Interface cable
« Reply #1 on: September 06, 2014, 07:52:27 AM »
"Dry" is an industry term that means "Dry Contacts", which means it is a "Relay contact",
i.e. NOT a Sinking or Sourcing contact.
So inside the machine, there are small relays that close (or open if it is NC).
It also means you can pass through your interface voltage (5vdc, 24vdc etc.) without worrying (unless your out side the relay ratings).
Look in your manual.
But for the most part almost any relay will handle 5v to 110v sometime more, it could be
AC or DC as well. Dry contacts give the user the greatest interfacing options on control systems.
Scott
« Last Edit: September 06, 2014, 07:54:39 AM by poppabear »
Offline BLM
  •  37 37
« Reply #2 on: September 06, 2014, 09:09:13 AM »
Thanks Scott, now I need somebody to tell me what each wire does. This is my first experience with "industrial plasma cutters" so I'm not sure which controls Mach3 will use!
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #3 on: September 06, 2014, 10:38:16 AM »
Hi Brian
If I were you I'd ask on the Hypertherm forum at cnczone. When I was designing my THC Jim Colt (of Hypertherm) was very helpful.
Ian
Offline BLM
  •  37 37
« Reply #4 on: September 06, 2014, 01:16:41 PM »
Thanks for that Ian!
