Hello Guest it is November 22, 2026, 05:28:53 PM
Author Topic: Reset button clears machine coordinates  (Read 14176 times)
« on: September 03, 2014, 01:13:08 PM »
For some reason the machine machine coordinates is set to zero when I press the "reset" button.
Steps:
Press "ref all home" button and wait for homing to complete.
Load a G-code program and run some lines. The machine moves away from zero position.
Pressing the "reset" button then set machine coordinates to zero
If I restart the program the work position is moved the distance to where I pressed reset
Is there anyone there has an idea what is happening?
I assume I can use the reset button to stop a program if I want to change something.
System:
mach3 ver: 3.043.066
CSMIO/IP-M controller
Best regards Uffe
Re: Reset button clears machine coordinates
« Reply #1 on: September 04, 2014, 03:03:54 AM »
I can add some more information. Maybe this can give a clue of what is wrong.
After homing when pressing reset one time "E stop button pressed" message is showed. When pressing Reset a second time the home LED's turns off and machine coordinates is set to zero.
The softlimits does not work.
X-- and X Home shares the same input.
Soft limit X min=1 max=100
After homing I can still pass the soft limits
When I jog X+ pressing "right arrow key" the DRO counts positive and the machine moves positive however I have unchecked "X home neg" to get the home direction negative. According to the tutorial video "X home neg" should be checked to home in negative direction.
best regards
Uffe
« Reply #2 on: September 04, 2014, 03:48:48 AM »
I found out that there has been an issue similar to this in the CSMIO firmware so I have now asked CSLAB directly.
Uffe
« Reply #3 on: September 05, 2014, 02:43:31 AM »
Have a look in the plugin and see if there is an option for coords setting to zero on reset.
« Reply #4 on: September 08, 2014, 05:30:46 AM »
Thank you for reply.
Yes there is an "set axes to zero at reset" option and it is default set active.
« Reply #5 on: September 08, 2014, 05:35:02 AM »
If you Uncheck it then when you press Reset it will not zero the coords.
