Hello Guest it is November 10, 2026, 01:57:20 AM
Author Topic: homing macro and Ismoving  (Read 40597 times)
Offline TPS
  •  2,627 2,627
« on: August 31, 2014, 09:18:48 AM »
Hello together,
first of all excuse my bad english.
after hours of searching i will post my problem here.
i have written a small macro for auto homing and clearing home limit swtiches if
necessary.
here the code:
Code: [Select]
Sub Main()
' TPS 30.08.2014
' Referenzschalter freifahren und anschliessend Referenzieren
'beim Laden des Files Abbrechen
If IsLoading() Then
    GoTo Ende
End If
Message ("Automatische Referenzfahrt")
'Referenz INI Z freifahren
If GetOEMLED(836) Then
Code "G91" ' Inkremental Modus
Code "G0 Z-50" ' Freifahren
WaitMoving
Code "G90" ' Absolut Modus
End If
'Z referenzieren
DoButton(24)   'Zuerst Z
WaitMoving
'Referenz INI X freifahren
If GetOEMLED(830) Then
Code "G0 X-50" ' Freifahren
WaitMoving
End If
'Referenz INI Y freifahren
If GetOEMLED(833) Then
Code "G0 Y-50" ' Freifahren
WaitMoving
End If
'X und Y referenzieren
RefCombination(3) ' dann X und Y
WaitMoving
Code "G54" 'Koordinatenverschiebung ein
Sleep(200) 'warten
    Message (" ") 'Stauszeile löschen
Exit Sub
Ende:
 Message ("Automatisches Referenzieren Abgebrochen")
End Sub
'Funktion zum warten bis Antrieb steht
Function WaitMoving()
Sleep(200)
While IsMoving()
Sleep(200)
Wend
End Function
sorry for the german comments.
the problem ist that the macro hangs in about 1 of 50 tryes
at the line
   While IsMoving()
line. if i press the stop button
i get the message:
internal error at line ..
i have no idea what i am doing wrong.
Thanks Thomas
Re: homing macro and Ismoving
« Reply #1 on: August 31, 2014, 09:30:04 AM »
Try removing the Sleep(200)'s from the WaitMoving function.
All you need is :
While IsMoving()
Wend
Offline TPS
  •  2,627 2,627
« Reply #2 on: August 31, 2014, 12:25:26 PM »
Hello Gerry,
tryed this already, but i figured out
that without the sleep it does not
wait after the
DoButton(24)
for z-reference.
Thanks Thomas
« Last Edit: August 31, 2014, 12:30:59 PM by TPS »
Offline TPS
  •  2,627 2,627
« Reply #3 on: September 02, 2014, 01:14:15 AM »
Hello,
back again after additional testing.
i tryed
Code: [Select]
Sleep(200)
While IsMoving()
Wend
crashed at line While IsMoving() with internal error
i tryed
Code: [Select]
While IsMoving()
Wend
did not stop after the DoButton(24)
i tryed
Code: [Select]
Sleep(200)
While Not IsStopped()
Wend
crashed allways at line While Not IsStopped() with internal error
maybe i am searching at the wrong side of the road, because i am
using a csmio/ip motion controller and do not know whether this
function call (IsMoving()) is only handled by Mach Software or
also by the plugin.
possibly i have to talk to the csmio/ip people.
Thanks Thomas
« Reply #4 on: September 02, 2014, 03:16:36 AM »
I think you can change your home off distance in homing and limits config. to clear the switches by any amount you wish. I think you will continue to have problems as long as you use the while IsMoving() in the reference all button while using CSLabs. If you do ask CSLabs I would be interested in hearing their explanation.
Offline TPS
  •  2,627 2,627
« Reply #5 on: September 02, 2014, 03:26:50 AM »
Hello Brett,
i emailed CSlabs the problem.
will get back to you with the response.
Thomas
Offline TPS
  •  2,627 2,627
« Reply #6 on: September 02, 2014, 02:12:01 PM »
ok, small update,
i am sure it is not the Ismoving() thing.
replaced it with:
While GetOEMled(999)
Wend
should be the same i thought.
but i am geting no internal error anymore, it just hangs.
for the moment i am out off any ideas.
looks like i have to to accept, that it is not
working 'sometimes'.
with no idea what i can do if it is not working (automaticly)
just frustraiting.
Regards Thomas
« Reply #7 on: September 02, 2014, 02:22:14 PM »
I had the same idea and tried the same with the same results. I had to just do it another way. Really, the way the CSLabs handles homing I figured out there was no need for the While IsMoving() in my script. I am acustomed to haveing to add a move away from the switch in my homing script. CSLabs will do this for you without altering the script. Just set your home off distance in Mach.
Offline TPS
  •  2,627 2,627
« Reply #8 on: September 03, 2014, 01:52:12 AM »
Hello Brett,
i thought this HOME OFF DISTANCE is the distance
witch is driven after the homing, i am gona test this today.
what i want to do with my script is to clear the homing limits
before i start a homing, because it is not homing when its
on an limit.
Thomas
Offline TPS
  •  2,627 2,627
« Reply #9 on: September 03, 2014, 03:43:21 AM »
Hello Brett,
her the answer for CSLab
Dear sir,
Homing is an autonomous function of CSMIO/IP motion controllers and Mach3 may have a problem with IsMoving() function.
To control if homing is finished you can use LED diodes  GetOemLed(807)  / GetOemLed(808) / GetOemLed(809).
DoButton( 22 )
Sleep(200)
While GetOemLed(807) = true
    Sleep(50)
    If GetOemLed(800) Then
        Sleep(500)
        Message"Error"
        End
    End If
Wend
Message"Axis referenced"
 The way shown above works perfect
Regards
Wojtek Trawicki
Thomas
« Last Edit: September 03, 2014, 03:44:56 AM by TPS »
