Hello Guest it is November 22, 2026, 02:42:50 PM
Author Topic: On input signal estop?  (Read 7740 times)
« on: August 25, 2014, 02:34:51 PM »
Hello,
I have servo drivers who gives High signal on servo failure.
I have added that signal as input1 in Mach3.
Now I don't know how to configure Mach3 to go to estop when input High,
and maybe to display "servo failure". Just maybe.
Any help would be nice.
Thanks, Ivan
Re: On input signal estop?
« Reply #1 on: August 27, 2014, 04:43:43 AM »
There is a check box on General Config page to make Mach sop on Input1 signal.
To do the message part you could use a Brain or the macropump to inform you.
Personally I would use the macropump and have it also E-Stop Mach when Input 1 is seen.
