Hello Guest it is November 12, 2026, 06:10:30 AM
Author Topic: Just a little beginners help with brains  (Read 14495 times)
« on: August 20, 2014, 05:20:12 PM »
New to brains, just need a little push to get started.
I want to set the pulley from an input. I currently have
Input3 - compare=0 - formula = 1 - dro current pulley
Input3 - compare=1 - formula = 2 - dro current pulley
I change the input and nothing happens. Is this the right approach? I swear just point me in the right direction and I will figure it out from there!
Re: Just a little beginners help with brains
« Reply #1 on: September 01, 2017, 02:26:30 PM »
The INPUT block always activates/works changes state as ":0 or :1"  correctly when i toggle my physical switch or a MACH3 LED
HOWEVER , I also can't get the  COMPARE block to activate on simple on/off 1/0 inputs regardless of weather the input is a hardware switch (INPUT1) or a  MACH3 LED (tested with "Continuous Jog" LED )…so the common problem is that they are digital/boolean
I tried with the COMPARE block being : =1 and also with >0 …won't activate either way
I CAN get it to work with non booleans like when the INPUT block is the X axis DRO.  And the COMPARE block is ">0"….as a test, unfortunatley I want use a brain with a physical switch as an input.
