Hello Guest it is October 22, 2026, 05:57:14 PM
Author Topic: Bug in G77 / M1077 macro  (Read 13827 times)
« on: August 18, 2014, 05:42:48 AM »
Because mentionend in the Turn Handbook, i tried the G77 / G78 canned cycles. But in G77 I found two bugs.
Line 48-52 must be:
Code: [Select]
If( Taper = 0 ) Then
  ZCalc = Abs(StartZ - EndZ)   'was ZCalc = 0, which ignores EndZ further on
Else
  ZCalc = Abs(StartX - EndX) /Tan((Taper * PI)/180)
End if
and Line 71-74 must be:
Code: [Select]
  If IDOD =1 And PassDia <= EndX Or IDOD =-1 And PassDia >= EndX Then        'was < and > instead of <= >=, which causes to repeat the final cut
   PassDia = EndX
   LoopExit = 1
  End If
seems that nobody has used these two since creation (2009).
Re: Bug in G77 / M1077 macro
« Reply #1 on: August 29, 2014, 09:51:40 AM »
Seems that they were some other bugs in that macro too. I'm going to rewrite it with a roughing and a sizing stage - like in the wizard. But the OD Turning wizard has also a kind of bug inside. If you've a tool with an angle of around 80°, then you'll produce a nice crash in the sizing stage. Because after the last turning, it continues the z axis move to Z End and removes all the material at once because it takes the turn from inside out - it has to be the other way.
« Reply #2 on: October 01, 2014, 06:15:24 AM »
I've solved my problems by rewriting the M1077 and M1078 macros. I use them quite often, because it's the simplest way to machine standard parts on the lathe - by combining G77 / G78 words. It first does roughing with the values in the general options when no h word is given and makes a sizing move with 40% feed and 40% of the roughing amount. Also, it evens the roughing passes out so that they are all the same amount. So, here is my code, without warranty of course:
M0177:
' G77
'(Xx.*********x XDia NEEDED)
'(Zx.*********x End Z NEEDED)
'(Fx.*********x Feedrate)
'(can be Set In the settings page: 'Hx.*********x Depth of cut)
'(Cx.*********x Clearance In the X)
'(Qx.*********x Clearance In the Z)
'(Kx.*********x ZStartpoint)
'(Rx.*********x XStartpoint)
'(Tx.*********x Taper In Deg)
Sub Main()
ZClearance = Abs(tZClear()) 'This one it not avalable
XClearance = Abs(tClearX())
StartX = tXStart()
StartZ = tZStart()
EndX = tEndX()
EndZ = tEndZ()
Taper = tTaper()
FirstPassDepth = tFirstPass()
RoughAmount =  abs(tCutDepth())
Feed = Feedrate()
SizingAmount = RoughAmount * 0.4
SizeFeed = Feed * 0.4
PI = 3.1415926
If StartZ > EndZ Then
    RightLeft = 1
Else
    RightLeft = -1
    ZClearance = ZClearance * -1
End If
If StartX < EndX Then   'Inside Turning
    IDOD = -1
    XClearance = XClearance * -1
Else
    IDOD = 1           'Outside
End If
'Calc the distance X needed to make the taper angle
TaperX = Abs(StartZ - EndZ)* Tan((Taper * PI)/180)
If TaperX > Abs(StartX - EndX) Then
    EndZ = StartZ - Abs(StartZ - EndZ) * RightLeft * (  Abs(StartX-EndX) / TaperX )
    TaperX = Abs(StartX - EndX)
End If
code "G0 X" & StartX + XClearance & " Z" & StartZ +  ZClearance
code "F" & Feed
PassNum = 1
LastPassDia = StartX
'optimize roughing value
Passes = (Abs(StartX - EndX) - SizingAmount) / RoughAmount
If CInt(Passes) <> Passes Then
    passes = CInt(Passes) + 1
    RoughAmount = (Abs(StartX - EndX) - SizingAmount) / Passes
End If
Do  'Roughing Loop
    PassDia = StartX - (RoughAmount * IDOD * PassNum)
    code  "G0 X" & PassDia
    If TaperX <> 0 And Abs(PassDia-EndX) < TaperX + SizingAmount Then
        'Taper turn section
        ZCalc = StartZ - RightLeft * Abs(( (StartZ - EndZ) * (Abs(PassDia - EndX) - SizingAmount)) / TaperX )
        code "G1 Z" & nFmt(ZCalc,4)
        If (Abs(PassDia-EndX) < TaperX + SizingAmount) And (Abs(LastPassDia-EndX) > TaperX + SizingAmount) Then
            code  "X" & EndX + (TaperX + SizingAmount) * IDOD & " Z" & EndZ + SizingAmount * RightLeft
            code  "X" & LastPassDia
            PosZ = EndZ + SizingAmount * RightLeft
        Else
            ZCalc = StartZ - RightLeft * Abs(( (StartZ - EndZ) * (Abs(LastPassDia - EndX) - SizingAmount)) / TaperX )
            code "X" & LastPassDia & " Z" & nFmt(ZCalc,4)
            PosZ = nFmt(ZCalc,4)
        End If
        If PassNum = Passes Then Exit Do
        code  "G0 X" & LastPassDia + XClearance & " Z" & PosZ + ZClearance
    Else
        'Straight turn section
        code  "G1 Z" & EndZ + SizingAmount * RightLeft
        If Abs(LastPassDia - PassDia) < Abs(XClearance) Then
            code  "G0 X" & PassDia + XClearance & " Z" & PosZ + ZClearance
        End If
    End If
    code  "G0 Z" & StartZ + ZClearance
    LastPassDia = PassDia
    PassNum = PassNum + 1
Loop
'sizing
code "F" & SizeFeed
If Abs(EndX - StartX) > TaperX Then
    If TaperX = 0 Then
    End If
    code "X" & StartX + XClearance
    code "Z" & EndZ
    If TaperX <> 0 Then
        code "G1 X" & EndX + (TaperX + SizingAmount) * IDOD
        code "G0 X" & EndX + XClearance + (TaperX + SizingAmount) * IDOD & " Z" & EndZ + ZClearance
    Else
        code "G1 X" & PassDia
        code "G0 X" & PassDia + XClearance & " Z" & EndZ + ZClearance
    End If
End If
code "Z" & StartZ + ZClearance
code "X" & EndX
If TaperX = 0 Then
    code "G1 Z" & EndZ
    code "X" & PassDia
Else
    code "G1 Z" & StartZ
    If Abs(StartX-EndX) > TaperX Then
        code "G1 Z" & EndZ & " X" & EndX + TaperX * IDOD
        code "G0 X" & EndX + (TaperX + SizingAmount) * IDOD + XClearance & " Z" & EndZ + ZClearance
        code "X" & StartX + XClearance & " Z" & EndZ + ZClearance
    Else
        code "G0 X" & StartX + XClearance & " Z" &  EndZ + ZClearance
    End If
End If
code  "G0 X" & StartX & " Z" & StartZ
code "F" & Feed
End Sub
Main
M0178:
'G78
Sub Main()
StartX = tXStart()
StartZ = tZStart()
EndX = tEndX()
EndZ = tEndZ()
Taper = tTaper()
RoughAmount =  tCutDepth()
Feed = FeedRate()
PI = 3.1415926
    IDOD = -1
Else
    IDOD = 1
End If
    RightLeft = 1
Else
    RightLeft = -1
End If
If Taper <> 0 Then
    TaperZ = Abs(StartX - EndX) /  Tan((Taper * PI)/180)
    If TaperZ < Abs(StartZ - EndZ) Then
        EndZ = StartZ - TaperZ * RightLeft
    Else
        TaperX = Abs(StartZ - EndZ) * Tan((Taper * PI)/180)
    End If
End If
code "F" & Feed
PassNum = 1
LastPassDepth = StartZ
Passes = (Abs(StartZ - EndZ) - SizingAmount) / RoughAmount
    Passes = CInt(Passes) + 1
    RoughAmount = (Abs(StartZ - EndZ) - SizingAmount) / Passes
End If
Do
    PassDepth = StartZ - (RoughAmount * PassNum * RightLeft)
    code "G0 Z" & PassDepth
    If taper <> 0 Then
        XCalc = EndX + IDOD * Abs((StartX - EndX) * (Abs(StartZ - PassDepth) + SizingAmount) / TaperZ )
        code "G01 X" & XCalc
        XCalc = EndX + IDOD * Abs((StartX - EndX) * (Abs(StartZ - LastPassDepth) + SizingAmount) / TaperZ )
        code "X" & XCalc & " Z" & LastPassDepth
        PosX = XCalc
        code "G0 X" & PosX + XClearance & " Z" & LastPassDepth + ZClearance
    Else
        code "G1 X" & EndX + SizingAmount * IDOD
        PosX = EndX + SizingAmount * IDOD
        code "G1 Z" & LastPassDepth
        If Abs(LastPassDepth - PassDepth) < Abs(ZClearance) Then
            code "G0 X" & PosX + XClearance & " Z" & PassDepth + ZClearance
        End If
    End If
    LastPassDepth = PassDepth
Loop
'sizing
code "F" & SizeFeed
If Taper = 0 Then
    code "G0 X" & EndX + SizingAmount * IDOD + XClearance & " Z" & EndZ + SizingAmount * RightLeft + ZClearance
    code "X" & EndX
    code "G0 X" & EndX + XClearance & " Z" & EndZ + SizingAmount * RightLeft + ZClearance
Else
    code "G0 X" & PosX + XClearance & " Z" & EndZ + SizingAmount * RightLeft + ZClearance
End If
code "Z" & EndZ
code "G1 X" & StartX
If taper = 0 Then
    code "X" & EndX
    code "Z" & EndZ + SizingAmount * RightLeft
    code "G0 X" & EndX + XClearance & " Z" & EndZ + ZClearance
Else
    If Abs(StartX - EndX) > TaperX Then
        code "X" & EndX + IDOD * TaperX
    End If
    code "X" & EndX & " Z" & StartZ
    code "G0 X" & EndX + XClearance & " Z" & StartZ + ZClearance
End If
code "F" & Feed
End Sub
Main
« Reply #3 on: October 02, 2014, 11:31:19 AM »
If you use the Tooltable, then these macros have an additional error: The "T" word initiates a tool change and/or the taper. So, you have to rewrite them with a variable for the taper.
« Reply #4 on: October 02, 2014, 07:28:06 PM »
Just a quick note to say thanks for taking the time to document this.  I'm not far enough along in my CNC lathe odyssey to fully understand what you're talking about but enough so that I feel a little less responsible for some of the unexplained crashes I've had.  Keep up the good work! ;D
Milton from Tennessee ya'll.
« Reply #5 on: April 24, 2015, 01:50:33 PM »
Solving the taper issue is easy - i forgot to post it here:
in the macro, you should edit the line
taper = tTaper()
to
Taper = GetVar(101)
SetVar(101,0)
If Taper > 90 or Taper < 0 Then
   message "Error, Taper out of Bounds"
   code "M30"
   Exit Sub
End If
so it takes the taper angle from a user variable and resets it after use. in the GCode, program prior to your macro call #101=45 , if you want something different than zero.
« Reply #6 on: September 07, 2016, 07:59:02 AM »
Because I don't want to update the code at two locations here the link to my personal page with the last version of the macros:
http://www.stephan-brunker.de/Maschinen/Software/body_software.html#M1077
« Last Edit: September 07, 2016, 08:01:18 AM by stephanbrunker »
« Reply #7 on: September 07, 2016, 05:04:36 PM »
stephanbrunker,
Never used the lathe macros for G77 and G78 in all these years. :D
Thanks for pointing out the bugs and fixes.
Much appreciated......keep up the good work,
