Hello Guest it is November 22, 2026, 11:49:31 AM
Author Topic: Steppers high vibration problem  (Read 10972 times)
« on: August 17, 2014, 03:40:29 PM »
Hello,
I bought 3 Nema23 stepper motors and TB6560 3axis driver. After connecting them together by following the instructions from supplier, steppers are spinning roughly with high vibrations or not spinning at all (just vibrating). I set the parameters of Mach3 according to this user manual http://www.omc-stepperonline.com/download/pdf/3_Axis_TB6560_CNC_Driver_Board_Users_Manual.pdf
Maybe it is worth to mention, that only Z axis is rotating (with high vibrations), X and Y axies are just vibrating.
I would appreciate any kind of help how to solve this problem. I'm attaching a video of the problem:
https://www.youtube.com/watch?v=dKG0240zKrg&feature=youtu.be
Thank you,
Marius
Offline tivoi
  •  29 29
Re: Steppers high vibration problem
« Reply #1 on: August 18, 2014, 12:05:39 AM »
check motor wire conection
b.r
« Reply #2 on: August 18, 2014, 05:33:19 AM »
Hi tivoi,
I took a picture of wiring. I was following user munual for wiring.
Should I determine wiring by using a multimeter ?
« Last Edit: August 18, 2014, 05:35:16 AM by MariusLT »
  •  9,378 9,378
« Reply #3 on: August 18, 2014, 07:53:12 AM »
Perhaps best just to check one motor - For those connections...  Red & Blue should show continuity and Green & Black should show continuity.  ;)
