Hello Guest it is November 01, 2026, 06:01:55 AM
Author Topic: G Code movement interrupted by an input.  (Read 9593 times)
« on: August 14, 2014, 07:23:28 PM »
Hi there. A simply newby question: Is it possible to interrup the GCdde vel constant movement of an axis by an external signal and then continue the movement with a constant desaceleration.
Thanks in advanced.
Offline Fastest1
  •  920 920
  • Houston, TX
Re: G Code movement interrupted by an input.
« Reply #1 on: August 24, 2014, 12:44:48 PM »
Of just a single axis? Or all? And why?
Btw, I would think yes as to changing it for all axis simultaneously. Not sure of the ability with a single axis.
« Reply #2 on: August 24, 2014, 07:23:01 PM »
For all axis. It is a pick & place machine resolved by CNC: MACH3, AKZ250, Delta Servo drivers & motor.
>And why?
I need to change the movement in answer to a proximity sensor signal mounted in the hand.
« Reply #3 on: August 24, 2014, 07:34:01 PM »
Have your sensor call the feedhold button.
