Hello Guest it is October 12, 2026, 03:30:49 PM
Author Topic: Weird 1/16 offset on X-axis  (Read 7524 times)
« on: August 13, 2014, 11:40:59 PM »
I've been staring at this too long. Hopefully, it's something really stupid and simple that I'm missing. A likely prospect, since I've been using Mach3 for a very short time. I took a job with a company that has Mach3 on a 3-axis router and a 4-axis wire cutter. On the router, no matter what I do, it seems to set work zero 1/16th of an inch to the right of where I zero the work piece. Today, I think I eliminated toolpath issues by running the same part through two separate toolchains. The cut is accurate to the design, but the whole process is off to the x positive by 1/16th of an inch, so I believe the problem is something in Mach3. Can anyone give some hints where to look for a mystery offset?
Re: Weird 1/16 offset on X-axis
« Reply #1 on: August 15, 2014, 05:47:10 PM »
Not really sure what to suggest other than maybe you are using a different offset, in the code , than the one you are setting zero?
