Hello Guest it is November 22, 2026, 10:33:39 AM
Author Topic: Output signal  (Read 18832 times)
Offline Davek0974
  •  2,606 2,606
Re: Output signal
« Reply #10 on: August 16, 2014, 01:35:00 PM »
I think antidive works purely internally within Mach code, there is no output signal on my system at least, my THC is pretty dumb and has no in put from the PC, it just says up, down and arc-ok to mach, nothing more.
I guess the speed routine in mach just tells the system to ignore any down signal once speed drops below set point.
