Hello Guest it is November 22, 2026, 03:53:27 PM
Author Topic: Motor whistling only with Mach3  (Read 13341 times)
« on: August 12, 2014, 03:36:02 PM »
Hello,
I have just built my home-made CNC and I have a set-up problem, I guess.
When I'm using my CNC with my manual interface, no noise. However, when I launch Mach 3 - it means I desactive the Reset button - my stepper motors make a strange noise. Even if that noise don't impede my stepper motor to work, it's quite... annoying.
Do you have any ideas where the problem could be ?
Thank you for your time !
Re: Motor whistling only with Mach3
« Reply #1 on: August 14, 2014, 10:46:54 AM »
I have read the Mach3 documentation and... nothing.
Maybe a video could help to describe the problem,
https://www.youtube.com/watch?v=qWu4QUgrB1Y
« Reply #2 on: August 14, 2014, 12:01:41 PM »
try retuning the motors.
hope this helps !
Kenneth
« Reply #3 on: August 14, 2014, 02:09:28 PM »
hope this helps !
Do you mean try to modify stepper motor wiring ?!
« Reply #4 on: August 14, 2014, 03:23:55 PM »
What drives are you using. Some drives are just noisy, and there's nothing you can do about it.
« Reply #5 on: August 15, 2014, 06:05:45 PM »
Seem to recall that some, if  not all, of the TB type boards use full step when in external mode and that makes them quiet but when under Mach control the microstepping, set on the boards, comes into play and that can cause noise.
Could be totally wrong, often am ;)
« Reply #6 on: August 21, 2014, 06:13:03 AM »
under Config/Motor Tuning you're able to adjust the velocity and acceleration.
i had some noise and that helped me.
good luck !
hope this helps !
Kenneth
