Hello Guest it is October 21, 2026, 06:13:01 AM
Author Topic: Homing Switch is switched on how do I reverse this  (Read 8373 times)
« on: August 09, 2014, 01:37:58 PM »
Hello,
I have a homing switch that is depressed when mounted to the machine.  The normal position is when the switch is not depressed and I want to activate the home position when the switch is no longer depressed.
I can't seem to find a way to make Mach3 think that the depressed switch is the normal when not homed?  Is anyone familiar with my dilemma?
Lee
Offline BLM
  •  37 37
Re: Homing Switch is switched on how do I reverse this
« Reply #1 on: August 09, 2014, 07:47:06 PM »
I have a switch like this on my Z slide on my plasma table. The switches I purchased have three pins; NO (normally open) and NC (normally closed) and Line In pins. On my Z I have the switch pressed until it limits out so I used the NC pin. Then all my limit switches are configured alike in Mach 3. Wether possible to do that in Mach3, I don't know. I didn't try to figure that out because my switches came with either option. FWIW that my experience! Brian
« Reply #2 on: August 10, 2014, 01:25:59 PM »
if i understand you .then you go to ports and pins and change it from active low to active high
Mike
