Hello Guest it is October 21, 2026, 07:02:39 AM
Author Topic: Z touch plate, using alternate input  (Read 11056 times)
« on: August 07, 2014, 09:41:17 AM »
Hello,
I've had to redo my machine, and my Mach setup. (Long Story)  I've updated to latest version on Mach3 (plus addons)
But I'm to the point where I want to set up my auto zero for my Z. Then I can do my first "air" test cuts.
I want to use the touch plate mechanism, but.. I also want to use an input other than the probe port.
I want to do digitizing with my machine as well... I want my touch plate and my digitizer probe to co-exist on my setup. But if my research is correct, one wants to be active low, and the other active high.  I don't want to go into setup-ports-and-pins, everytime I switch between activities. (cause I know I'll forget, and bugger something).
I've got the BOB wired, so I'm OK there.
I need an auto zero VB script that will use on of the generic input (say input 1) instead of the "Digitizing" input.
Thank-you in advance...
Re: Z touch plate, using alternate input
« Reply #1 on: August 07, 2014, 10:37:51 AM »
Use a Brain to trigger the Probe input.
For Example:
Setup the Probe as Input 1, and the Auto Zero as Input 2.
Create a brain to trigger the Probe input whenever Input1 or Input 2 are active.
Do not use the Probe input, or the Brain won't work correctly, from my experience.
« Reply #2 on: August 08, 2014, 07:56:37 AM »
The Brain did the trick.. thank-you.
The Brain is pretty simple. The two inputs are Input 1 and Input 2.  Each has a "no operation" lobe. This passes the setting on.. The next lobe is a "OR" operation of the previous two lobes.  And then it terminates with setting the "Probe" signal. I then went into ports and pins config, and disabled the probe input. I might not need the "no operation" lobes, but it works, I'm not going to go back and futz with it.
It works a treat.
The cool part now, is once I start to digitizing, I can zero out the digitizing probe with the same auto zero routine. My metal touch place is 1/8" thick, by putting a piece of scrap between the object and the digitizer probe, I can zero it out.  That should save me  some digitizing time because the Z won't have to travel as far.
Thank-you again....
« Reply #3 on: January 11, 2017, 09:13:34 PM »
hello there ranger and ger,
can you please take a screen shot of what the brain would look like. i am trying to do the exact same thing.
thanks much
