Hello Guest it is October 20, 2026, 03:04:36 PM
Author Topic: Mach3 lathe. Homing speed goes to rapid and crashes Z at 175ipm despite...  (Read 7087 times)
I have mach 3 lathe running well, except that (after I run a program) if I home X and Home Z via the home buttons, the homing feedrate precentage I have entered in the homing/limits page is ignored. Then, my X and Z rapid to the home switches, and in the case of the Z, this is currently at 175IPM.
I suspect that I need something at the end of my lathe gcode to cancel out any previous feedrate modification, and to allow the homing sequence to occur at the 20% of rapid speeds that I am set at(on the homing limits page)
I think the above paragraph is the issue, because if I close out of Mach and restart, it will preform the homing at the correct 20% of rapid speed.
Any thoughts?
