Hello Guest it is October 20, 2026, 02:51:04 PM
Author Topic: Issue with Mach3 under XP  (Read 7950 times)
« on: July 22, 2014, 10:06:00 AM »
Hi guys, sorry if this is the wrong section could'nt see an xp based problems section.
I have been running mach 3 under xp and after working 2 hours through a 4/5 hour rough cut an error appeared on the screen. Art Code: 9991...now I am leaving the machine running to complete the path but can any one shed light on what this means and what has caused it...
thanks in advance
chris.
Re: Issue with Mach3 under XP
« Reply #1 on: August 03, 2014, 01:19:53 PM »
Are you using any plugins?
If not change the name of the plugin folder to something like OldPlugins then create a new, empty,  folder called Plugins.
Hopefully that may help.
