Hello
Guest
it is
October 20, 2026, 03:04:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
running 2 CNC machines from 1 pc
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: running 2 CNC machines from 1 pc (Read 11039 times)
ringo42
1
on:
July 20, 2014, 07:54:01 AM »
I have 2 CNC machines. I would like to be able to just unplug the parallel port cable from 1 and plug into the other and use the same PC. They are completely different machines however. Different pinouts, etc. Is there any way to do this with mach3? Any way to store different profiles or anything like that?
Logged
mc
384
Re: running 2 CNC machines from 1 pc
Reply #1 on:
July 20, 2014, 05:26:08 PM »
Easily.
Just create different profiles, and select the relevant one when you load Mach.
Logged
magicniner
265
Reply #2 on:
July 23, 2014, 05:38:44 PM »
A friend of mine uses a good quality 2-way parallel port switch to swap between lathe & mill
Logged
JohnHaine
975
Reply #3 on:
July 31, 2014, 05:14:54 PM »
Me too. Have a converted Myford S7 and a Denford Novamill, separate profiles called Myford and Denford, and a switch box I bought from an online computer supples place. Works fine as long as I remember to set the switch properly!
Logged
Reply #4 on:
August 01, 2014, 06:00:00 AM »
PC, controller,MPG's , etc all mounted on a compact movable cart works well for me.
Logged
Print
Pages:
1
Go Up
« previous
next »
