Hello Guest it is October 21, 2026, 09:28:21 AM
Author Topic: Problems communicating with CNC  (Read 9284 times)
« on: July 19, 2014, 06:18:22 PM »
First things first I am a newb but not clueless and have tried a number of things to solve my issues but now I come to you for help.
So I bought a homebuilt CNC from a yard sale and everything seemed to work well.  I declined to purchase the computer they had hooked up to it because I already have several "beater" systems at home.  I get it home and find I have to use a parallel port, no biggie I go to newegg and purchase one.  Few days later it comes in I install it and hook everything up.  Now I can't get mach3 to communicate with the motors or the computer to communicate with the breakout board.  To be honest I'm not sure which.
Did some reading and figured out I need to assign the port and pins inside mach3 and I do so, after I search and search for info on my breakout board which had no markings of any kind.  I eventually find what I think it is, photo attached, and assign pins as directed by it's documentation, no dice.  I triple check my newly installed pci parallel card to confirm the port and it seems to check out.  I checked the bios and could not find any options there.  So now I am clueless and coming to you guys.
I will note I did watch the machine run at the yard sale so Im fairly confident that nothing is broken but who knows.
Windows 7 64bit
mach3, was given to me on a flash drive.  I am not confident it was not a pirated copy so after I hit post here I am going to uninstall and reinstall the demo version from this site and give it one more go.  I fully intend to purchase the full version once I get up and running.
Ask any questions you need
Photo I took of the actual Breakout board
Documention I found for the breakout board after exhaustive googling.
Parallel Info my Device Manager
Basic settings
Port and pins settings
Thank you in advance for any assistance.
Re: Problems communicating with CNC
« Reply #1 on: July 19, 2014, 06:44:41 PM »
  •  9,374 9,374
« Reply #2 on: July 20, 2014, 04:53:22 AM »
As Ozymax mentioned you will not be able to use the parallel port with a 64 bit OS.
Not that it will help but I also notice that you entered the address 0x800 as your Port#1 in Mach - it should be 0xC800.
