Hello
Guest
it is
November 11, 2026, 11:14:20 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
HOW DO I SET THE Z CUT DEPTH???
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: HOW DO I SET THE Z CUT DEPTH??? (Read 19651 times)
EtchNCut
2
on:
July 16, 2014, 11:52:36 AM »
OMG I'm about to snap!!!! Learning Mach3.... I've figured everything else out by trial and error but for the life of me I can't seem to find a simple answer to a simple question: How do I set the Z depth for a particular thickness of material on a cnc router?
I have a wooden substrate on the cnc table to protect the aluminum table. I have 3mm G10 to cut on top of that.
If I set the Z stop to zero at the surface of my material then:
How do I set the plunge depth to go to the bottom of the material and cut it but not all the way to the table?
If I have 2mm material, how do I change the cut depth? If I want to cut a pocket half way through a 4mm material... HOW DO I SET THE CUT DEPTH???
Thank You in advance to whomever can save me from myself in this conundrum....
Last Edit: July 16, 2014, 11:55:00 AM by EtchNCut
Logged
EtchNCut
2
Re: HOW DO I SET THE Z CUT DEPTH???
Reply #1 on:
July 16, 2014, 12:37:52 PM »
Scratch the 2mm bit... I just need to know how to adjust the depth of my plunge for different heights above the table...
Currently the gcode shows a movement between 1.0 and 0...
Logged
Reply #2 on:
July 17, 2014, 05:52:33 AM »
You manualy program Gcode for what you want to machine or use a program that generates the code .
Programming Handbook by Smid covers most everything you need to know and will be a valuable resource
for learning and use in the future.
Logged
ger21
6,295
Reply #3 on:
July 17, 2014, 06:22:51 AM »
How are you creating your g-code? If using a CAM program, you set it there. If hand coding, you add a Z move to plungeto the depth you want.
If Z zero is the top of your part, then to cut 2mm deep, you'd do something like:
G1 Z-2
Logged
Masta
6
Reply #4 on:
September 28, 2014, 04:20:03 PM »
Basic proramme this is what your deths should look like in xilog
XG0 X=395 Y=-20 Z=-10 s=0 T=127 F=1 C=1
XL2P Y=135
XAR X=445 Y=185 r=-50 G=2#
XL2P X=1100
Logged
tonywads
41
Reply #5 on:
November 30, 2014, 11:10:11 PM »
Z sets the depth of your cuts g1 z-1 will cut 1mm if your machine is set to mm g1 z-2 =2mm g1 z-3 =3mm ect... to lift g0 z1.5 would lift 1.5 mm above you work
when you drop your z depth down using keyboard leave you bit loose then once close, pull bit onto work surface and tighten
Logged
Print
Pages:
1
Go Up
« previous
next »
