Hello Guest it is November 23, 2026, 03:12:31 PM
Author Topic: Stepper direction one way only!!!!!!!  (Read 7951 times)
« on: July 10, 2014, 09:06:45 AM »
While machining the x axis freaked out and kept going in the same direction. When I stopped the machine I tried moving the table and the x axis would only go in one direction whether I pressed the right or left arrow. This happened 2 years ago and vanished when I updated the software. The problem has  reappeared again.
Is it a Mach3 problem or controller problem or a Microsoft problem ? Or none of the above?
Mach3 currently has version R3.043.067
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Stepper direction one way only!!!!!!!
« Reply #1 on: July 10, 2014, 02:01:29 PM »
Most like you have a problem with your stepper cable. If only one coil in the stepper motor is getting power the motor will spin only one direction and/or randomly change directions each time you try to move it. You should also check that your direction signal is changing when you change the motor direction.
Happy machining , Jeff Birt
