Hello Guest it is November 01, 2026, 10:13:31 AM
Author Topic: Confused about LCAM versions  (Read 23797 times)
Re: Confused about LCAM versions
« Reply #10 on: March 26, 2007, 12:44:59 PM »
Manuals will have to be after we get the software matured. i would think that you are looking at about 6 months before we even start the manual.
www.newfangledsolutions.com
www.machsupport.com
Offline Vogavt
  •  260 260
« Reply #11 on: March 26, 2007, 07:55:22 PM »
What you stated is mostly true, For latest ver of LazyCam D-load Mach3R2.00.060 or latest Ver above under Downloads, "Mach releases".
Okay, now my head's starting to hurt....
I downloaded the latest Mach3 2.00.060 (which I thougt was supposed to have the latest LCAM) and installed it only to find an LCAM version of 2.00.060 (yep, same number as Mach3).
The file LazyCam.exe (v 2.00.060) has a file size of 4,244 kb and contains multiple options (including grayed out LcamPro)
The file LazyCam.exe (v 2.66) has a filesize of 2,284 kb but also has fewer options. (not even sure now where/when I got that version).
That being said, it appears that the version 2.00.060 is the latest regardless of the version numbers!
Is this correct?
« Reply #12 on: March 29, 2007, 08:10:37 AM »
You are correct and the Revs will increment up from the 2.00.060 rev
www.machsupport.com
