Hello Guest it is October 23, 2026, 06:16:41 PM
Author Topic: Help major XYZ axis problems after a 2 month break...  (Read 9063 times)
« on: June 30, 2014, 11:12:27 AM »
I have been using Mach 3 for a couple of years without any major problems.
After a break for a couple of months, I turned my machine on and did the usual startup.
but….even though cables haven't been swapped the following crazy behaviour was noted:
If I use the keyboard or toggle for the Y axis, the direction of the motors is reversed.
The Y axis buttons on keyboard or toggle control the spindle!
and the up and down buttons or Z axis toggle, does nothing.
How can this happen?
Pins and ports look good.
Can anyone help on this?
Simon
Re: Help major XYZ axis problems after a 2 month break...
« Reply #1 on: July 01, 2014, 01:44:24 PM »
Attach your xml and I will see if there is anything obvious there.
« Reply #2 on: July 01, 2014, 04:16:52 PM »
great thanks,
How do I do that?
simon
