Hello Guest it is November 01, 2026, 10:13:31 AM
Author Topic: Lazy Cam Pro  (Read 14001 times)
carguy944
Lazy Cam Pro
« on: March 23, 2007, 12:20:29 AM »
I recently downloaded the latest copy of Lazy Cam and there are all these really cool disabled features that say "LCAM Pro".
When can I get it?  Will it be free with Mach?  I could really use it!
I posted this once before, and I thought I offended someone, but then I just read that 2 days of posts were lost.  So if I did offect a moderator, sorry for reposting. :)
Gabriel
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lazy Cam Pro
« Reply #1 on: March 23, 2007, 12:25:14 PM »
Hi, Gabriel
LazyCam Pro is in latest down load of Mach3R2.00.060.
To use the added features you need a license, Look in Downloads, Plugins above.
From what I've gathered a $50.00 fee which will be good for final release Ver, Will increase to $100.00 sometime in the future.
Hope this Helps, Chip
Offline Chip
  •  2,055 2,055
Re: Lazy Cam Pro
« Reply #2 on: March 28, 2007, 01:22:46 AM »
Hi, Art, Brian
Turn is going to be "Nice".
Mach3R2.00.061, There seem to be some line confusion and several G02, G03 Raid errors Mem out, WOW !!, What a Start for Turn.
Thanks, Chip
Re: Lazy Cam Pro
« Reply #3 on: March 29, 2007, 08:11:58 AM »
Go to the ports and pins page and tell it to revers the Arcs and it should work for you :)
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
Re: Lazy Cam Pro
« Reply #4 on: March 29, 2007, 02:07:21 PM »
Hi, Brian
I try ed the Rev. Arc as you stated, Just big circles with that.
It's not just the Arc's, First straight line are cutting deepest cut's first.
My Turn Options are X mode Diameter "checked" and Rev. Arc's in Front "checked", Had to edit code missing G01 at bottom of code.
I'll post screen shot with courser cut's smaller DXF and Tap Files.
Thanks, Chip
OK, Thanks
« Last Edit: March 29, 2007, 03:02:22 PM by afn09556 »
Re: Lazy Cam Pro
« Reply #5 on: March 29, 2007, 02:14:54 PM »
I will have to do that after I am done with the A axis stuff... I have done so much that Lathe will not work at this point. This should be one of the last big things that I have to add (I hope).
Thank you for the feedback Chip
Brian
www.machsupport.com
