Hello Guest it is November 13, 2026, 08:09:06 PM
Author Topic: Tool change?  (Read 11056 times)
Tool change?
« on: June 21, 2014, 02:55:22 PM »
In my code I have tool changes set in the code.
 When i start mach3 tool change ignore is selected as a default. is there a away to configured mach 3 to default the tool change ignore to see the tool change in the code.
So i wouldn't have to go click the ignore button every time mach 3 is started.
Re: Tool change?
« Reply #1 on: June 21, 2014, 03:35:07 PM »
Dont really follow what you are meaning but there are 3 options for tool change on the General Config page.
Ignore
Stop spindle wait for start
and finally
Auto
First does exactly that, it ignores any tool calls in your code.
Second will stop the spindle and wait for you to press Start and continue. I also think the M6End macro may be used in this instance.
Last will look at the M6Start macro and do whatever is in it.
Re: Tool change?
« Reply #2 on: June 22, 2014, 03:40:45 PM »
sorry got in a little rush had to leave when i posted maybe this will help
when i open mach 3 the ignore tool change is active, is there away to default it where tool change is not ignored a start up off mach3?
i keep forgetting to switch it before running a program.
Re: Tool change?
« Reply #3 on: June 22, 2014, 03:47:21 PM »
Options 2 or 3 mentioned above will set Mach to default to them.
Re: Tool change?
« Reply #4 on: June 22, 2014, 04:08:47 PM »
thanks
